how to remove duplicate element in an 2D array
Hi ,
I am new to labview. I have a 2d array,in that I have to remove the duplicate elements and also wanted to count  duplicate elements.I have included the example for it.Screenshot (82).png
(4,327 Views)
Hi sanjay,
You have a 2D array control, but you only show the first column:
  • What data is in the other columns?
  • How do you define "duplicate" elements: compare only the first column or the whole row?
  • When the other columns aren't of interest then why don't you use an 1D array right from the beginning?
  • Do you use a string array or numeric data?
What did you learn from your other thread?
What have you tried to solve that homework on your own?
Why don't you attach an example VI containing reasonable default data in your array control? (You should have learned to attach code from your other thread!)
(4,317 Views)
Hi ,
Here I have attached my code. In that code it will remove all the repeated elements but what I need is like only the continuous repeated element should be removed and also I have to count the repeated elements. And I am getting the input from the textfile.
(4,291 Views)
Accepted by sanjay92
Hi sanjay,
In this VI of yours there is nothing done at all because the code is broken…
Just a suggestion:
This code mostly does what you need, but not completely. Improve it on your own!
It doesn't matter where the data comes from: this function should use a 1D array control as input!
What's the point of using a 2D array input with only the first column used?
(4,267 Views)
Can you please sent the image for true case also.It will be helpful for me to understand.
(4,254 Views)
The true case should be quite obvious once you understand the problem. (Hint: two items are just wired across unchanged)
Of course one does not really need a case structure or 2D arrays. Here's my suggestion. See if you can recreate it from the picture, a good exercise! 😉
(4,224 Views)
Thankyou for your help.And now I can able to understand the data flow.
(4,198 Views)
