how to remove old NI Imaq if it is not in add remove programs
I am upgrading from 6i to 8.o fo rlabview and vision development module.
I need to remove my old IMQ before the new one will install.  It is not listed in my add/remove programs.  How do I remove it?
(2,906 Views)
Here is a link to a vi that will read the add/remove programs list from the registry. It also lists the uninstall file. Maybe this will give you a clue if IMAQ is still hanging around.
http://forums.ni.com/ni/board/message?board.id=170&message.id=142804#M142804
Message Edited by unclebump on 01-25-2006 05:41 PM
(2,894 Views)
Hi rscconrad,
IMAQ 2.5.1 was a subcomponent of the LabVIEW installation and will reinstalling LabVIEW to remove the component.
  1. Uninstall LabVIEW 6.x using Add/Remove Programs. This will remove the previous version of IMAQ.
  2. Install LabVIEW 6.x (or if possible, just install LabVIEW 8.0).  You will need to customize the 6.x installation so that IMAQ 2.5.x is not installed.
  3. Proceed with your upgrade.
I hope this works for you.
RyanF
Message Edited by RyanF on 01-26-2006 02:07 PM
(2,877 Views)
Ryan,
You were correct.  That worked perfect.
Thanks for the help
(2,860 Views)
