how to remove "main" breakpoint?
Hellon guy, probably this is the dumbest question ever asked on this forum...Smiley Very Happy
therefore I expect you to answer me Smiley Wink
I don't know how, but I accidentally set a giant breakpoint to the whole VI... this comes in seeing a big
red rectangle around my block diagram, just like in the figure.
How do I remove it????
Right click on the VI doesn't work (on the "red frame" it doesn't wrk, either); from edit menu (I'm using labview 7.1, there isn't any "remove breakpoints" command. From "browse>breakpoints"  can see two breakpoints but I can't remove them (no "del").
What should I do?
TNX A LOT!
(3,234 Views)
Hi CAPITANEVS,
press shift and right click on the blockdiagram. Select the break point tool and click then again on the blockdiagram.
Mike
(3,233 Views)
One more option:
Hold the CTRL key, and move your pointer over the VI, if the breakpoint tool changes from a 'red' inner to a 'white' inner you can remove the breakpoint.
Ton
My LabVIEW Ideas
(3,200 Views)
