Hellon guy, probably this is the dumbest question ever asked on this forum...
therefore I expect you to answer me
I don't know how, but I accidentally set a giant breakpoint to the whole VI... this comes in seeing a big
red rectangle around my block diagram, just like in the figure.
How do I remove it????
Right click on the VI doesn't work (on the "red frame" it doesn't wrk, either); from edit menu (I'm using labview 7.1, there isn't any "remove breakpoints" command. From "browse>breakpoints" can see two breakpoints but I can't remove them (no "del").
What should I do?
TNX A LOT!
