how to replace a specific row from 2D array?
how replace a specific row from 2D array?
thank you
vicens
Win XP/LV 7.1
(4,591 Views)
Try what's in the attached picture.
Message Edited by Will.D on 11-07-2006 10:56 AM
(4,586 Views)
Thank you, Will.D
it's possible search a row in a 2D array string?
(4,577 Views)
Of course!  But it's hard to offer good advice without knowing what you're trying to do exactly.
Do you know the row number?  Are you searching for a row or an element within a specific row?  Are you comparing strings?
The answer shouldn't be hard, just need some more info!
(4,571 Views)
This VI works good but only in the case when I don't repite the control. When I switch on a case control, this case appears in row '0' in the array. If switch off the same control change in the row '0'...OK. If I proceed with other case control works too. But if I switch on the case control of the beginning this case appears in other row.
I think that I have to search the index of the row to replace, but the index changes each loop.
sorry for my english...
vicens
(4,564 Views)
Hi vicens & everybody,
I think your problem is because of 2 things:
1. You forgot about inserting the 0 into the false case in the case structure where you save the time.
2. You used replace array instead of insert into array.
I attach you the vi with the C case solved (the A & B) ones are still wrong as you got them previously. As you will see you detect all the changes for the C case. If you make an ON/OFF  you detect both changes.
Jaime Cabrera
NI Applications Engineering Spain
Jaime Cabrera
(4,548 Views)
HI,
I think now I got what u wanted to do....
Is that right 3 files one for each button??????
I think is that thing... see attached vi.
Jaime Cabrera
Ni Applications Engineering Spain
Jaime Cabrera
(4,532 Views)
