replace 1D array string in 2D array string unknowning index
I have 3 contols (Case A, Case B and Case C) and one array that shows only one time the status of the controls (TRUE or FALSE) and the message ([F?][0?.01][hh:mm:ss][nº message]). The example works if switch on one control and switch off the same control the next time. But if swicth on the control again, appears 2 status in the array: that last and the status when I switch off.
The objective is show only 3 rows, everu row for one different control.
Can you help me, please?
Thank you.
Win XP / LV 7.1
(3,439 Views)
Hello Vicens,
I think that what you want it's simple. But I've a problem. My current version o labview (8.2) doesn't allow me to save into your version. So I can't send you the changed .vi. But in attach i'm sending pictures of it. I hope it could help you.
Changed:
 - Replace the insert array vi to replace vi (case true). In case A connect a constant row 0, Case B constant 1, case C constante 2
 - Don´t change the array value in case false
 - initialize the array 3 by 4 with a space
Best regards
Software developer
www.mcm-electronics.com
PORTUGAL
(3,420 Views)
Thank you Jorge, I will do.
(3,411 Views)
Hi all,
Is this the same issue as it is in
http://forums.ni.com/ni/board/message?board.id=170&message.id=214179
Jaime Cabrera
NI Applications Engineering Spain
Jaime Cabrera
(3,395 Views)
HI,
I think now I got what u wanted to do....
Is that right 3 files one for each button??????
I think is that thing... see attached vi.
Jaime Cabrera
Ni Applications Engineering Spain
Jaime Cabrera
(3,385 Views)
