how to reproduce a word
Hi! I need some help with my project.
I want to reproduce a sequence of strings, and i don't know how.
Is there a function that 'speaks' a string, being the string one input?
(3,427 Views)
hello Manieri,
could you be a little bit more explicit?
Do you mean generating sound from strings ?
Regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(3,412 Views)
You will need to use third-party software to "speak" text. If you're on a Windows machine you can try using Microsoft Speech. Examples have been posted before, so you might want to take a look at them to see if they are close to what you're looking to do. Post back if you need further help.
(3,409 Views)
Sorry if I didn't explained it very clear, it's because my english isn't very good.
This is exactly what i need, generate sounds of the strings.
(3,406 Views)
Thanks for the help!!!!!!
(3,402 Views)
