how to return to loop
I am enjoying using the State Module. How many levels down can you go down? I wasn't sure if I would need a flat file and create new State Modules in each flat file. I have a 15 step test procedure with all kinds of speacial conditions.
Philip
Message 11 of 13
(893 Views)
Just as a point of clarification, are you using the statechart module?  If so, what version of the statechart module are you using?  Have you tried using the state machine archeticture that everyone has suggested?
Applications Engineer
Message 12 of 13
(867 Views)
The subject is ironic, seeing as it seems this thread has come full circle and looped back to where it started....Did he mean state machines? Or did he use no suggestions that were given to him?
pnielsen@gplains.com wrote:
I am now working with State Modules. This has improved the software structure dramaticaly. My thanks to all of the help I recieved.
PhilipSmiley Very Happy
Message 13 of 13
(860 Views)
