how to reverse 2d array
I have a silly question: this works well when reversing columns. How would you do it to reverse lines? Would you just transpose it, reverse it, and transpose it again?
Cheers,
Fl0
Message 11 of 16
(1,421 Views)
Hi Flonares,
Yes.
Btw. message #10 already handles both cases!
Message 12 of 16
(1,408 Views)
With the openG function you can reverse by row or column
Ben64
Message 13 of 16
(1,401 Views)
Your question is silly in more ways than you might think! 😄
  1. We have a long thread with many examples and we have absolutely not idea what you mean by "this".
  2. Most examples here already reverse rows (lines?), not columns. Where is the confusion?
  3. Several posts already talked about other array transforms.
... so... what was your question again???
Message 14 of 16
(1,386 Views)
Hi Gerd!
I actually hovered over it and did not recognize immediately that it did both things - now I feel silly indeed! Thanks for pointing it out.
Cheers,
Fl0
Message 15 of 16
(1,348 Views)
You make a very valid argument - I skimmed some examples on the surface but did not realize until I went back and read the thread again that there were further examples already fully developed - so yes, silly me! Anyways, skimming through this thread was actually gold because it´s actually an simple example but with quite robust solutions.
Cheers!
Message 16 of 16
(1,344 Views)
