how to round down rather than automatic round up at .5
I really have lost my brain cells to work out suitable formula to achieve this!
I need at all cost be able to round down on the result of an equation. Obviously Labview compliant with IEEE would always round up at/above .5. Is there a way to achieve what I am after?
Many thanks
K Waris
ATE and Labview Consultant
https://www.easybodge.com
(4,594 Views)
Accepted by k-waris
Does Round Toward -Infinity do the job?
(4,587 Views)
Define .5. What about .4999999999999.
Up or down?
There is no such thing as exactly .5.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,553 Views)
Sorry, but that's not correct.  Dividing any integer by 2 gives a floating representation of that integer times 2^(-1)..  To see the "exact" representation of, say, 9/2, typecast it to an array of U8 (bytes), and you'll see 64 18 0 0, exponent and mantissa.
BS
(4,506 Views)
Many thanks
K Waris
Actually, the statement in bold is untrue.  IEEE standard for "round to nearest" is "round to even integer", which is the rule that LabVIEW follows.
http://zone.ni.com/reference/en-XX/help/371361H-01/glang/round_to_nearest/
Bill
CLD
(Mid-Level minion.)
(4,441 Views)
That solved my problem. Thank you
(4,435 Views)
Note that this method might not work like you want for negative numbers. If you want -3.2 to round to -3, you will need to check the sign and if negative round to +inf.
___________________
Try to take over the world!
(4,418 Views)
