how to run a VI for very short time, e.g. 100ms?
Hi
Somil: I have Labview 8.5 so am unable to run the VI you attached. Thanks anyway.
I've attached the VI. There are two problems I'm facing.
1) It runs fine in highlight mode but otherwise it doesn't show any values in the "Macro" and "Micro" arrays, which it should.
2) The value coming out from the multiplication operator, which is connected to the "time" array is absolute time in picoseconds. I want the user to be able to enter the time in miliseconds in "Numeric 4", and the "Macro" and "Micro" arrays should only contain data according to that time. Note that the absolute time is itself a function of the "Macro" and "Micro" values. The problem I am now facing is that at each iteration, the "Macro" and "Micro" arrays directly get Max/2 values in one go, so I the time that the user enters has no effect on them.
Kaiser
Message 11 of 20
(1,021 Views)
Hi kaiser
first of all, i am attaching the VI for 8.5 version
secondly, your vi is missing some of the subvis (see attached pic) because of which i am unable to view your code
Somil Gautam
Think Weird
Message 12 of 20
(1,015 Views)
One thing i want to ask. Why have you set the default values of the dimension of arrays so high???
Is this also the requirement of your code or its by mistake?
Somil Gautam
Think Weird
Message 13 of 20
(1,010 Views)
thnx for the VI. will consider this option for implementation.
 attaching the SubVis.
Message 14 of 20
(1,008 Views)
thnx for the VI.
You might like to say it officiallySmiley Very HappySmiley Very HappySmiley Wink
OK, i am checking your VI now
Somil Gautam
Think Weird
Message 15 of 20
(1,004 Views)
Hi Kaiser,
comments on your code:
- never use a STOP function in your code - use a case structure around the remaining code...
- try to avoid all those coercion dots: maybe you could change this (missing) GetFifoData.vi to give data in DBL? You do all calculations in DBL, even scale by 1E-6 and the display the result as U32 (time)? I don't know what values you're working on, but I would expect a lot of zeros or rounded values in your display.
- At the moment you compare the time array with your numeric4, but always display the full micro/macro-arrays. There is nothing that limits the arrays to the interesting values... Here again a coercion occurs as Numeric4 is I32. So you calculate in DBL, display in U32 and compare with I32. Any reason for that?
Message Edited by GerdW on 10-30-2009 08:53 AM
Message 16 of 20
(1,003 Views)
Still missing
ok, for your future applications, try using LabVIEW project if you have so many Subvis. this will keep your code organized.
Somil Gautam
Think Weird
Message 17 of 20
(1,001 Views)
either use a project or put all vis in one folder (maybe using subfolders): this way you can provide one zip-file with all files needed in just one upload…
Message 18 of 20
(995 Views)
thnx for your prompt replies. As for the different data types, the VI contains parts from three different sources thats why. I didn't check for these differences. Will amend it.
Message 19 of 20
(973 Views)
Hi Kaiser,
even with different sources you should have to take care of correct (in terms of datatypes/coercions/rounding errors) calculations...
Message 20 of 20
(971 Views)
