how to run a labview program(*.vi) in VB6?
Hi:
I use measurement studio 6 and VB6. I want to run a labview program(*.vi) which is no parameters to input to judge whether spectrum ananlyzer is in ready state.How can I run the program?
Thanks for your help!
(2,554 Views)
@laoseasailor wrote:
Hi:
Check out Active X. LabVIEW (and the runtime engine if you build a small mini executable with the LabVIEW application builder) can work as Active X server which can be invoked by VB to load and execute a VI.
There should be quite a few samples in the Development Library on this site for this.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(2,548 Views)
