how to run .exe file by labview?
Dear All,
I want to use Labview to run a .exe file, but I don't know how to do? who can tell you? Thanks!
Jimmy
Message 1 of 22
(26,819 Views)
Under all Functions>>Communication>> There is a function that is called system exec.vi.  This vi will allow you to launch an exe using a command line protocol.  Look at the help for this function.  hope this helps.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
Message 2 of 22
(26,800 Views)
Try the attached VI (LV v7.1.1). It uses the System Exec function:
(from the LV Help file):
"System Exec
Executes a system command. UNIX You can use wildcards, pipes, and shell meta-characters. Mac OS To use this VI on Mac OS, you must have the Macintosh Programmer's Workshop installed. Refer to the Apple Developer Connection Web site for information about downloading the MPW.
To launch an executable with options using the syntax filename.exe -option1 -option2, create a filename.bat file that calls the executable with the options syntax and use this VI to call the filename.bat file. "
Message 3 of 22
(26,801 Views)
Thanks a lot. I can run a .exe file by labview now.
by the way, do you know how to program to close a widcomm bluetooth driver or anyother device driver?
Jimmy
Message 4 of 22
(26,794 Views)
Hi, I cannot understand how to pass or get some parameters to a file.exe.
I remember that I was able to pass them directly in the command line, but cannot remeber how.
Thanks a lot.
Message 5 of 22
(26,688 Views)
I forgot the example...
Message 6 of 22
(26,683 Views)
Try this vi.  It should help you.
BJD1613
Philips Respironics
Message 7 of 22
(26,668 Views)
Thanks, but I have already downloaded fron the net a similar example. I still have the same problem. I create a Filename.vi  that has an input and an output. I create the Filename.exe but I can't pass it any parameter to the input and get any parameter from the output.
What I remember from DOS is a command line like this: >filename.exe par1 par2 parN . But it does not work.
Thanks a lot for your help
Message 8 of 22
(26,660 Views)
What .exe are you trying to run? Not every program accepts command line parameters and not all of the accept them in the same manner. What does the exe documentation say?
Message 9 of 22
(26,658 Views)
It sounds like he has created a VI called FileName that has a front-panel input and output. He has turned the VI into a standalone executable and cannot figure out why its front panel controls/indicators don't couple to command-line arguments.
Message 10 of 22
(26,652 Views)
