camera for hair level crack detection connected with myrio
Hi
dear members i am working on egg crack detection . i have done finding the crack by using many  ni forum member's suggestion its was helpfull. now i again need your suggestion for selecting the camera.
camera should be
autofocus , high resolution so that it can capture hair level crack, will be visible on picture , and also can connect with myrio (like usb 2.0  cameras ) , (any other specification if you think it should be in camera for small crack detection) .
your suggestion will be appreciated and i will be thankful to you
(2,975 Views)
I would recommend taking a look at this document in order to calculate your camera's sensor resolution according the crack that you want to inspect: https://www.ni.com/en/support/documentation/supplemental/18/calculating-camera-sensor-resolution-and...
Once you have determined your camera sensor, you will also need to decide your frame rate and whether you want a color or mono camera.
Unfortunately, National Instruments does not recommend any USB 2.0 cameras BUT our hardware and software supports most USB 2.0 devices that are DirectShow compatible. (https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6COSA0&l=en-US)
Therefore, as long as your 3rd party camera follows the DirectShow acquisition, you should be able to use it with your myRIO.
I hope this helps! Good luck!
T. Le
Vision Product Support Engineer
(2,906 Views)
