how to run more then 1 event at a same time.
You need to keep your question in one place.
Right now you have the SAME question in three threads:
http://forums.ni.com/t5/LabVIEW/how-can-I-make-easier-case-structure-Or-can-it-possible-to-have/m-p/...
http://forums.ni.com/t5/LabVIEW/how-to-perform-reset-operation-after-performing-one-operation/td-p/2...
And this thread.
Don't get your hope too high on getting a response when you start having multiple post on the same question.
Close this thread and http://forums.ni.com/t5/LabVIEW/how-can-I-make-easier-case-structure-Or-can-it-possible-to-have/m-p/...
And continue in this http://forums.ni.com/t5/LabVIEW/how-to-perform-reset-operation-after-performing-one-operation/td-p/2...
And if this hasn't been said before, I will say it, you need to take the basic courses in LabVIEW.
You are misusing local variable big time.
Take the courses slowly and focus only on the courses, let your current program be for a while.
Message 11 of 15
(557 Views)
hello,
I m really very confuse about ,how to generate event srtucture of my vi, so i have one pause and one reset event in that.
will you please guide me that how can i make event structure of my vi??
thank you very much,.
Message 12 of 15
(534 Views)
Message 13 of 15
(531 Views)
hello,
I want to do reset operation ,means when ever i press reset button my vi shoud be reset at that time only.
here i attached one example vi,will you please guide me that how can i perform reset operation in this vi.
Thank you very much,.
Message 14 of 15
(510 Views)
hello ,
can you please tell me that how can i disable other section or tread  in which i did same post.
Thank you.
Message 15 of 15
(492 Views)
