 simimasa
			simimasa
			12-16-2014 11:48 AM
Hi, I'm working on using the DAQ digital output to control the DAC digital input, but I have a problem on how to secure the wiring for the digital output to DAC. As when I plug the cable to the hole, it's loosely connected. Any suggestions on how to secure the wiring are appreciated.
Thanks in advance!
Solved! Go to Solution.
 RavensFan
			RavensFan
			12-16-2014 12:03 PM
It's a spring terminal.
Try pushing in the orange tab with a screwdriver while pushing in the wire. Let go of the tab before letting go of the wire and it should grab and hold the wire. It may be a case of lifting up the orange instead of pushing it in. You should be able to figure it out.
12-16-2014 12:07 PM
It works. Thank you!
