how to see the channels and device configured in MAX in Labview 6.0 that is in DAQ channel viewer
i am having labview 6.0 evaluation version.
In the DAQ channel viewer, i can't see my virtual channels that i configured in MAX and also my DAQ device that is PCI-6024E instead i see some sine, temparature channels and PCI-MO device.
Does evalaution version support PCI 6024E
(2,643 Views)
Hema,
The LabVIEW Evaluation Version gives the option of installing simulation DAQ VI's. If the complete install option is chosen, the simulation VI's are installed, as you are seeing in MAX. To avoid this choose a custom install and don't allow the Evaluation Version to install NI-DAQ. After the LabVIEW Evaluation Version is installed, install NI-DAQ and include support for LabVIEW 6.0. The DAQ VI's will now read data from your DAQ device and your board will recognize properly in MAX. To find the right version of NI-DAQ, go to http://www.ni.com/support/install/
Have a great day!
(2,643 Views)
