03-14-2007 12:57 PM
03-15-2007 12:14 AM - edited 03-15-2007 12:14 AM
Hi madgreek,
I'm [still] having trouble understanding what's needed.
You seem to have at least two desired results in mind, a visual representation for the data (you want to see a Chart,) and some result that will assist subsequent "characterization". We've already built a data-structure that identifies the voiced-segments present in the original signal, perhaps that array (along with the original signal data) is sufficient to allow the further processing you mention. As of your last post, it looked like you had solved some wish to Chart data a certain way.
As I'm not seeing the result you're picturing, I'm afraid you'll need to spell it out for me. Whether the result you desire is Charted or not, any "result" must exist as data. At a minimum you should be able to give an example listing input-data with corresponding result-data. Please include with the example, a precise description of how to derive each element of result-data from the given input-data. If you will do that, then maybe I can assist you in using LabVIEW to achieve what you're picturing! ![]()
Cheers!
Message Edited by tbd on 03-15-2007 12:15 AM
03-15-2007 12:28 AM
hey tbd
i know what you trying to say,...its hard to understand what i am trying to do...i will try and figure out something here (maybe something simpler) and i will get back at you at some point for some help on labview...that is if i need some ![]()
again thank you for all your help and time...
regards
madgreek
03-15-2007 01:15 AM
Well, I'm slow - so I'll apologize in advance for not understanding (now) what will seem simple later.
...however, maybe a really good description of what is needed will make the "how" more obvious.
You're welcome - just hope my participation hasn't discouraged someone else, who might actually have helped. ![]()
Cheers!
03-15-2007 01:20 AM
03-15-2007 02:04 AM
