how to select a item form listbox and insert it into combo
i want to select a item from listbox and display it in combo ,how realize ?
and how to insert a vi into a subpanel and excute?
everyone's help will be appreciated
(3,277 Views)
to add in Listbox selected item to Combobox see attached Vi. With the other part of our question must help someone other because I never did it.
Message Edited by ceties on 10-18-2006 04:57 AM
LV 2011, Win7
(3,276 Views)
To learn how a subpanel works, take a look into the following LV example (use NI Example Finder):
Building User Interfaces >> General >> simple.vi
Rasputin
Rasputin
LV7.1 <> W2K
(3,260 Views)
Sorry henryfg,
I didn't read your post properly until I found your other thread here. So Ignore my previous reply.
What happened to you couldn't cause attached Vi. Problem is elsewhere. Try to follow Altenbach's suggestions in next thread. And next time pls try to write your posts to Message Body. Writing to Subject is confusing. Thanks and Good luck!
LV 2011, Win7
(3,192 Views)
