Hello, to add in Listbox selected item to Combobox see attached Vi. With the other part of our question must help someone other because I never did it.
Sorry henryfg, I didn't read your post properly until I found your other thread here. So Ignore my previous reply. What happened to you couldn't cause attached Vi. Problem is elsewhere. Try to follow Altenbach's suggestions in next thread. And next time pls try to write your posts to Message Body. Writing to Subject is confusing. Thanks and Good luck!
