how to select resolution of PC for customer for running LV App?
My GUI occupies 1250x812. (assuming  this is the pixel value. this is measured using the set width and height -> resize object option).  what resolution PC should I suggest for the customer who is going to run this GUI?
Thanks!
(2,760 Views)
Accepted by topic author pcs82
1280 X 1024.
List of common resolutions
SXGA (1280x1024)
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(2,744 Views)
Presumably there's a reason you can't adapt your GUI to operate at a different resolution?
Since 1250*812 isn't quite widescreen (16:9) and certainly isn't standard (4:3) either, your options are to either change your GUI, scale your LV GUI to fit, or move to the next higher resolution (e.g. 1344x840) and black out the unused pixels.  Thoughts?
-John Sullivan
Problem Solver
(2,741 Views)
You should have asked the customer what type of displays they have and designed the gui based on feedback from them.
(2,712 Views)
