how to send a sinusoidal signal to an AO with a fixed phase difference with aother sinusoidal signal from an AI? Thank you!
In a While Loop, read a sinusoidal signal from an AI, extract frequency, amplitude and phase, and send a sinusoidal signal to an AO with a fixed phase difference and same frequency with the AI signal.
Thank you very much!
Marlon
(2,702 Views)
    The simplest way I would do it if the system pemits (without RT, FFT, convolution etc)  :
Set AO and AI with the same clock,
Connect two of AO channels with two of AI channels.
Generate AO voltalge ( sin , and cos ) near the expected frequency,record it at AI  together  with your signal.
Multiply your data with sine and cosine data and then integrate the product.
Iterate the frequency till you get maximum integral at one of the channels.
Add the desired phase difference.
_________________________________________________________________________________________________
LV 8.2 at Windows & Linux
(2,694 Views)
add to last message Smiley Happy : Probably instead of iterations it may be usefull to perform  FFT at
the beginning of application. And then to use the integral as some kind of PID controller, to be locked at the phase.
(2,684 Views)
