how to send command to Zebra T402 label printer using rs232
@Caritaxd24 wrote:
I need help because I'm really stuck.
You are responding to a discussion that was marked as solved in 2009 (!) and posted in a forum dedicated to LabVIEW.
If the above solution is not suitable for your situation, you should start a new thread. Also explain how it relates to LabVIEW and maybe attach your VIs.
Message 11 of 11
(44 Views)
