 GokulGKM
			GokulGKM
			06-23-2020 01:18 AM
hi,
how to separate the each excel worksheet in single workbook.
 altenbach
			altenbach
			06-23-2020 01:50 AM
Please explain how this question relates to LabVIEW.
It always helps to provide as much detail as possible.
			06-23-2020 02:48 AM
Hi Gokul,
Right-click the worksheet tab in Excel, select move/copy and move it into its own (new) workbook…
Maybe you want to ask in an Excel forum?
06-23-2020 04:22 AM
through labview i need to separate the worksheet form excel.
			06-23-2020 05:04 AM
Hi Gokul,
Which of the steps is a problem for you?
(I don't have MicrosoftOffice installed on this computer, so I cannot run your VI with its RGT functions…)
 PsyenceFact
			PsyenceFact
			06-23-2020 07:54 AM
Hi GokulGKM,
I can't open your file as I'm still using LV2015, but I've put together a quick example which should give you the right idea.
It opens the original file as read-only then makes a copy of each worksheet in a new workbook. If you want to move rather than copy, just change the Worksheet.Copy method in the loop to Worksheet.Move - the syntax remains the same. I haven't added any code to save the new workbooks so you can add it yourself or just save them manually as you require.
Hope this is useful.
PsyenceFact
07-01-2020 11:58 PM
Cannot Find "Excel.Application" Reference in LabVIEW.
but still can able to run your VI.but i can't able to edit or add property node.
07-02-2020 12:10 AM
Even tried like this method also it's not showing.
07-02-2020 12:37 AM
more information,
windows 10 OS with 64 bit
Microsoft office 64 bit
Labview 2016 32 bit
i can't able to convert labview and Microsoft office as same bit version.
 PsyenceFact
			PsyenceFact
			07-02-2020 03:29 AM
Since you are using the Report Generation Toolkit VIs to obtain the initial ActiveX references, you don't need the Automation Open node. Wire the Excel._Application output from Get ActiveX References.vi straight to the _Application.Workbooks property node. You should also replace the close Application reference with Dispose Report.vi.
PsyenceFact
