how to separate the each excel worksheet
hi,
how to separate the each excel worksheet in single workbook.
Message 1 of 14
(3,378 Views)
Please explain how this question relates to LabVIEW.
It always helps to provide as much detail as possible.
Message 2 of 14
(3,366 Views)
Hi Gokul,
Right-click the worksheet tab in Excel, select move/copy and move it into its own (new) workbook…
Maybe you want to ask in an Excel forum?
Message 3 of 14
(3,347 Views)
through labview i need to separate the worksheet form excel.
Message 4 of 14
(3,330 Views)
Hi Gokul,
  1. Some steps you need to take:
  2. open the exisiting workbook
  3. get a list of all sheets (and their names)
  4. for each sheet in workbook: read the sheet data and write to new workbook
Which of the steps is a problem for you?
(I don't have MicrosoftOffice installed on this computer, so I cannot run your VI with its RGT functions…)
Message 5 of 14
(3,319 Views)
Hi GokulGKM,
I can't open your file as I'm still using LV2015, but I've put together a quick example which should give you the right idea.
It opens the original file as read-only then makes a copy of each worksheet in a new workbook.  If you want to move rather than copy, just change the Worksheet.Copy method in the loop to Worksheet.Move - the syntax remains the same.  I haven't added any code to save the new workbooks so you can add it yourself or just save them manually as you require.
Hope this is useful.
PsyenceFact
Message 6 of 14
(3,305 Views)
Cannot Find "Excel.Application" Reference in LabVIEW.
but still can able  to run your VI.but i can't able to edit or add property node.
Message 7 of 14
(3,224 Views)
Even tried like this method also it's not showing.
Message 8 of 14
(3,220 Views)
more information,
windows 10 OS with 64 bit
Microsoft office 64 bit
Labview 2016 32 bit
i can't able to convert labview and Microsoft office as same bit version.
Message 9 of 14
(3,210 Views)
Since you are using the Report Generation Toolkit VIs to obtain the initial ActiveX references, you don't need the Automation Open node.  Wire the Excel._Application output from Get ActiveX References.vi straight to the _Application.Workbooks property node.  You should also replace the close Application reference with Dispose Report.vi.
PsyenceFact
Message 10 of 14
(3,198 Views)
