how to set boolean output high if its 5 boolean input high in proper sequence
you understand i point.
when i change boolean array with button its not working. i did this because i have to put shared variable in place of these button.
Message 11 of 20
(3,537 Views)
Use a case structure (no event structure) and poll the variable. Execute the case (containing my above inner code) whenever the boolean array differs from the previous state.
Message 12 of 20
(3,529 Views)
You need to be very careful, for example your array diagram constant still has hidden elements (container size != array size), so you need to delete those. It is better to show the last unused element (see picture) to make sure).
Here's what I meant with the polling of the values.
Message 13 of 20
(3,526 Views)
Thanks dear
i changed little in code then its not working.
can you make it correct ?
as i am not expert in labview 😞
Message 14 of 20
(3,510 Views)
Well, change it back 😄
Message 15 of 20
(3,503 Views)
Well, your blue array constant has too many elements. Since you are only looking at two switches, there should only be 3 element.
Your current array has an impossible transition where you need to turn one off and the other on in one step, which is not feasible. You should be able to figure out what the three values should be. *try 11,01, 00)
So you are trying to make so the order of the "20" switch does not matter? Why? Did the specifications change? Can you give it a more descriptive label?
(And please don't maximize the front panel to the screen. That's very annoying!)
Message 16 of 20
(3,501 Views)
Thank KNIGHT OF NI
You are genius!
now its working.
Thanks again
Message 17 of 20
(3,481 Views)
Accepted by Asif138
Not, it is not working. I told you that you need to check the array size. Just resizing the container does NOT change the array size. If you make the container larger, you can see that it contains four elements. You need to delete the fourth! See image.
Currently, if you turn one of the LEDs on and off first, you can never get the desired result. (e.g. try dock on, dock off, dock on, unlock on, 20 on. Should be unlocked but is not! Two 00 in a row can never occur again, because the array only gets updated when one changes.)
Message 18 of 20
(3,474 Views)
Brilliant! it is now working as i want. but truly i dont understand its working step because i am expert of Labview. i just know very basic.
Thanks Bro
Message 19 of 20
(3,457 Views)
Thanks Bro
Click on the light bulb to enable execution highlighting, then run the VI.  Besides it being really fun to watch all the dots go 'round, it is pretty good education in what happens in your LabVIEW block diagram.  Exceptions are when you need to see things happen in real time (including, but not limited to, instrument communications), or you have parallel processes going on.
Bill
CLD
(Mid-Level minion.)
Message 20 of 20
(3,441 Views)
