how to set up vi to read computer time
Accepted by topic author fotowat@uwindsor.ca
Yes.  That's the file.
See the attached modified VI and try it.  I could not work with the DAQ assistant since I don't have your DAQ device.  You should change that to fewer samples.  Right now you have 50 samples at 5 Hz which will take 10 seconds to read, which is right at the default timeout value.  Try making it 5 samples at 5 Hz.
I changed your waveform graph to a waveform chart.
Most importantly, I got rid of that unneeded To DDT in the middle of the blue wire.
Message 11 of 12
(787 Views)
Thank you so much guys for your help, much appreciated.
@ RavensFan, the file you provided is perfectly working now and recording the real time and date. Thanks alot for your help
Message 12 of 12
(778 Views)
