how to simulate pwm wave using labview
has anyone have a built vi for pulse width modulation(PWM),or give me pointer in building its simulation
(4,450 Views)
You have some elements on the link with a demo VI to simulate PWM.
http://zone.ni.com/devzone/cda/epd/p/id/5164
    Benjamin R.
Senior LabVIEW Developer @Neosoft
(4,448 Views)
dear sir,u insert a sub vi in the pwm vi right?how do u do it?
(4,441 Views)
If you just want to generate a PWM signal you can use a square waveform VI as shown in attachment. You can insert it directly in your code or create a subVI as you need.
Message Edité par BenjaminR le 03-06-2008 04:23 AM
    Benjamin R.
(4,427 Views)
