how to split a hexadecimal string into the required components
With my example I just used the default 32 bit number, you could use the same principle with a U64. Then it does start to get messy with the extra splits, in that case you would be better off with a loop and having your data in an array.
Message 11 of 15
(1,353 Views)
There are ways to do it without a for loop for any size array. But the answer isn't as clean as using a for loop. (Not sure which performs faster)
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Bernard Books
Message 12 of 15
(1,338 Views)
Hi
Could you post the snippet as a vi for LV 2010 please?
thank you
Regards
Freelance_LV
TestAutomation Consultant
Message 13 of 15
(1,324 Views)
Hello Freelance_LV,
As required.
Bijay
Message 14 of 15
(1,314 Views)
Thank you for the code Bijay.
I tried to reproduce the code by seeing the snippet, but missed out on 'Regular Expression' menu selection on the search and replace function. so, it didn't work.
thanks again
Regards
Freelance_LV
Message 15 of 15
(1,296 Views)
