how to stop the vi dynamically called out?
Some vi was dynamically called out by the attached vi, may I know how to close it using the vi reference. Thanks
(3,050 Views)
hi turbot,
if that is running first abort that vi using invoke node and then use the property Node of that vi reference That is Front Panel Window:open pass faulse value to close that vi. for more details check the attachment.
Santhosh M
(3,049 Views)
Sorry, I using 8.2, cannot open it.
And I open the vi by the attached screenshot.
(3,040 Views)
Accepted by alex.
Check att
Santhosh M
(3,033 Views)
