how to switch in case structure
Accepted by mamprat
It is because your cluster element have no label. You obviously cannot do something "by name" if there is no name.
You can use a regular unbundle (instead of "by name") or  right click each cluster element..properties.. and define a label (See image).
Message 11 of 12
(657 Views)
thanks sir the problem has been fixed, thank you
Message 12 of 12
(650 Views)
