how to take save picture from webcam
Hello
please see my attached VI, It working fine but when ever i press button to take picture and over write on previous image, how can i save all images in one folder.
Regards
asif
(2,386 Views)
You have got to modify your file path each time. Once way of doing this is below (I don't have 2020 so I cannot modify your snippet)
You could also use your iteration terminal to generate the file suffix but as I am guessing you don't always want to be recording an image to file I am guessing that will not be quite what you are after.
I also polling a button isn't the most efficient way of handling button presses. Research the event structure and for a more efficient and scalable alternative.
(2,357 Views)
Accepted by Asif138
A classic solution is to generate a filename from the time stamp, so it's named something like 211201-1515-332.jpg (todays date, 24h time, millisecond)
Qestit Systems
Certified-LabVIEW-Developer
(2,327 Views)
Another option is to use the increment file name generator built into LabVIEW since 2018(?)
Former Certified LabVIEW Developer (CLD)
(2,320 Views)
