how to take the sum of an a cluster
Hey Im trying to convert a matlab code into labview and i came across this issue with clusters. can anybody help?
  let's say:
[Pxx,w]=periodogram (mydata, [],[],var]
     time=sum(mydata.^2)/length(mydata)
     freq=sum(Pxx)
     Pxx=Pxx*time/freq
     Pxx=sqrt(Pxx)
     loglog(w,Pxx)
I manage to do the PSD of mydata, and translate time into labview code..
     but how do I take the sum of Pxx which is clearly going to be a cluster of 3 elements (magnitude, df, f0).. help?
Message 1 of 9
(5,014 Views)
The feedback forum is not for tenchical questions. I try to have this moved to the LabVIEW forum (since you mention LabVIEW).
Message 2 of 9
(5,008 Views)
I'd just run the waveform through FFT Power Spectrum and PSD VI found on the waveform measurements vis palatte.  (LabVIEW uses a default Hanning window so to match Matlab make sure you wire a "Rectangle" to the window input)
Message 3 of 9
(4,982 Views)
I thought this was.. yoou have the direct link?
Message 4 of 9
(4,967 Views)
Then how would I take the sum(PSD). Since the PSD come in a cluster....
Message 5 of 9
(4,963 Views)
Sure, Right Here
Export mode changes the output between PSD (Matlab Pxx = periodogram(x,window)) and Power Spectrum.  Esentiall the same as:
 Pxx = periodogram(x,window,power)
beyond that "summing" f0, df and an array of magitudes is adding apples to a bag of carrots what measurement are you expecting? (My Matlab is a bit rusty)
Message 6 of 9
(4,955 Views)
Accepted by topic author ritch_by_nature
My point exactly! so i decided to unbundle the Psd and do the sum of the magnitude array elements. then rebundle it with the f. and dt... not sure if that will work
Message 7 of 9
(4,938 Views)
You probably want something more like this:
but thats a guess...
Message 8 of 9
(4,924 Views)
Perfect!
Message 9 of 9
(4,900 Views)
