I was wondering if you had any luck with the batch processing function.
I found that the batch processing system:
Creates a separate file for each script step.
-The results for each subsequent image is appended to the data file with filename,date,time stamps
-The file names are however, not updated when stamped.
Is there a way to have a single output file per image, with each script step appended to it? Therefore full analysis of individual images are segregated together?
-Matt
Matthew Carney
R&D Engineer
The Polymer Technology Group
