how to typecast a table control to connect with VISA
- again Danil started a new thread...
- again Danil is asking new people to answer old questions...
- again Danil isn't providing enough information to be able to answer his questions...
Why didn't you stick with your original thread?
If you would understand the answers given in your other threads you wouldn't want to "typecast a table to a string"...
Message 11 of 13
(403 Views)
Accepted by topic author danil33
So you are using Spreadsheet String to Array and vice versa in your simulator and haven't figured out that this could be a solution for your Read From Port VI too? Of course this doesn't solve all the problems such as knowing how many bytes the VISA Read should read to receive the entire table, but hey you insist on this (IMHO quite nonsensical table to VISA problem) and haven't yet thought about the more general problem of reading data that has potentially varying size.
Rolf Kalbermatter  My Blog
Message 12 of 13
(402 Views)
Hi Rolfk,
                Thank you verymuch
Thanks as kudos only:)
Message 13 of 13
(392 Views)
