Unflatten from XML contains an input called Type. It accepts any LabVIEW datatype. Simply wire in a dummy constant of the cluster datatype that is stored in the XML file, and then create the indicator. You will see the indicator will automatically be the right type. Hope this helps!
	Jarrod S.
