how to use 9264 card with daq
Hi friends,
I m using labview 8.6 version. I hve interfaced labview with cdaq 9172.
I have used 9201, 9203 ,9219 card.Now i want to use 9264 card i.e analog output card.I am not getting how to use it .wheather  I hve 2 use on function plate express--> input-->daq assistant or something else.please help me. i want to control valve through 9264.i am sending some screen shot how i m trying 2 use.
(2,586 Views)
Hi Ajju
You can use the DAQ Assistant express VI, but since the 9264 is an output module you will need to choose "Generate Signal" instead of "Acquire Signal" in the dialog. Then you will specify what you want to output, from which channels, how fast etc. in the same maner as you do when acquiring a signal.
Hope that clears up teh confusion
Best Regards
David
NISW
(2,568 Views)
