how to use UMI 7764 is relied to a SMD103 drive to control a stepper motor
hi
I have a PCI 7350, relied to an UMI 7764 wich is relied to an SMD 103
my stepper motor turn all the time without any control
can anyone help me please?
(3,011 Views)
Hi mlevirus,
Try running an NI-Motion example or use the Motion Assistant. Check the links below:
http://www.ni.com/pdf/manuals/373329e.pdf
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8ZySAK
PedroR
(2,979 Views)
thank you for your answer
In Fact, I found the solution to make the motor move
now my problem is to find a sample of motion assistant program because the motor is not running well,
(2,965 Views)
You are welcome, check this link for information about installing NI Motion Assistant.
Regards.
(2,952 Views)
