how to use daq for pwm generation
Please some body help me solving this iam currently facing issues in providing daq assistance im trying to drive an h bridge dc motor i have used 2 knobs according to whisch the pwm changes
(3,406 Views)
I am not sure about your question.
What I understood is, you want to control a system from labview. Ok, What NI instrument or other you are using currently?
How much voltage or current do you need?
If you have a USB 6008/6009 then you can get maximum of 5v from it. Is it enough to drive your device?
              If so, please watch this and you will have all the information here.http://techteach.no/tekdok/usb6009/index.htm
(3,401 Views)
I dont have usb 6009 i have sch-68 how could i give input to my device which is a h bridge using this daq card
(3,393 Views)
Please help it will be exteremely helpful
(3,392 Views)
im giving the entire description of the instrument i am using the evice is ni pxie-1082
the data aquisition card is scb-68 its a m series device(P/N192187A)
(3,389 Views)
The SCB-68 is not a data acquisition device. It's a terminal block. It's used to interface a data acquisition device to your sensors. The PXIe-1082 is just a chassis. You actually need to plug in a data acquisition card into the chassis.
Please contact your local NI sales rep, as they can help you pick out the components you need.
(3,368 Views)
