how to use offset and multiplier property in waveform graph?
hello,
i m using a waveform graph and wanted to update its x-axis scale depending on the multiplier value. Also how this
formula of offset n multiplier works (deltaX)*X+X0? What is delta X and X?
vijtin
Message 1 of 11
(10,245 Views)
Accepted by vijtin
hi,
X0 is the offset and X is the multiplier.  So the graph will start at a cetain offset and will aa to that the delta value times the multiplier.
e.g.
If you would have these normal X-values : 0 ; 1 ; 2 ; 3 ; 4 ; 5 and a multiplier of 2 and ofset of 5 you would get the result on the X-as = 5 ; 7 ; 9 ; 11 ; 13
Hope this helps 😉
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
Message 2 of 11
(10,235 Views)
Thanks a Lot!!!
Message 3 of 11
(10,214 Views)
What's "deltaX"?
Message 4 of 11
(9,431 Views)
Delta refers to change - in this case the amount of change on the x-axis between points.
Message 5 of 11
(9,418 Views)
Can you give me example?
Message 6 of 11
(9,413 Views)
Your questions are highly ambiguous. I have no idea what you are looking for except in a very generic manner. Simply saying what is deltax is pretty meaningless all bt itself.
Message 7 of 11
(9,411 Views)
This mean is example in waveform graph. I want know deltaX when calculator (deltaX)*X + Xo. Purpose is control Multiplier in waveform graph.
Message 8 of 11
(9,404 Views)
How know deltaX when i want control multiplier in waveform graph?
Message 9 of 11
(9,401 Views)
The default multiplier/delta x for a graph is 1 and the offset (x start is 0). So, for example, you were plotting an array of values versus time, the first point would be at x=0, the second point would be at x=1, the third is at x=2, etc. If you were using a DAQ device and set if for 1000 samples/second, the delta x would be .001 (1/1000) and the graph would show samples every 1 msec. When you use a waveform data type, the graph can use the dt (same as dx) property of the datatype to automatically set the multiplier of the graph. Otherwise, you can use a graph property node to set the multipier. Right click on the graph terminal and select Create property node>XScale>Offset and Multiplier>Multiplier. Right click on the property node and select Change to Write.
Message 10 of 11
(9,399 Views)
