how to use read from spreadsheet file
i am new in using labview. i encounter a problem on how to read data from .xls file with multiple of sheets, and place the data into a 2D array.thanks
(3,064 Views)
Hi
If you go to the REPORT plate and check for EXCEL specific VIs then you can find a function that obtains the current worksheet data. You can use that several times to obtain whole set of data that is stored in various worksheets in a single file.
Kind Regards
(3,053 Views)
The function is Read From Spreadsheet and not Read From Excel. You can save your .xls file as a comma or tab separated file and then the function will work. Or, you can use ActiveX to read a native Excel file. If you search the forum or NI's example programs, you'll find a lot of Excel examples.
(3,049 Views)
Hi
http://zone.ni.com/devzone/devzone.nsf/webcategories/A50386FBB21ECC1A86256AB7006C2E6C
through here or the forum you can find resources relating your inquiery.
Kind Regards
(3,040 Views)
Sorry for the mix up
This is the correct link
http://zone.ni.com/devzone/devzone.nsf/webcategories/C3E56C69D399361E86256AB7006A9149
(3,038 Views)
