using Visa "resource name" control with GPIB example
good morning
I have in my pc two resources of GPIB (Ni-Enet and HP-HPIB card) each one has differet VISA name (ie:GPIB0,GPIB1)
means Ni-Enet is GPIB0 and HP-HPIB card is GPIB1.
I tries to use the example Labview<>GPIB to communicate with GPIB1 but it failes
because the address given (string), to the gpib write object is a string and it recognized only the GPIB0 addresses
i tried to use the "visa resource name" control (used in the example Labview<>Serial)
in the Labview<>GPIB example but it failed. ("visa resource name" shows all resources includes GPIB0 nad GPIB1)
tell me pleae how to use the Labview<>GPIB example to communicate with the equipment addresses used in GPIB1
a bit long , but hope the issue is clear enough..
thanks in advance
Happy new year.
Simon
(3,274 Views)
You can't use that example with an Agilent GPIB board. The GPIB functions are only for NI boards and the NI-GPIB driver. You should be able to convert it to VISA but you'll have to replace the GPIB Writwe/Read with VISA Write/Read as well as changing the GPIB Address String to a VISA Resource Name.
(3,256 Views)
