02-27-2012 12:53 PM
please help me in dis...i'm new to labview... i hav to interface chroma 6310a dc load to a PXI system using only RS232c communication in LABVIEW.. i found out the way that v hav to install related drivers before we start programming. so please help me to find out the driver, how to install it and do a successful programing
Solved! Go to Solution.
02-27-2012 01:22 PM
Tools>Instrumentation>Find Instrument Drivers or Help>Find Instrument Drivers.
On the main Instrument Driver Network page, you will find links that explain what an instrument driver is and how to use one. The available driver only supports GPIB but it is usually a minor change to support RS-232. This is something you will have to do yourself. Look at the 34401 driver that comes with LabVIEW to see a way that it could be done.
02-28-2012 06:38 PM
thanks for your reply. But I don know what changes to make, please can you show me sample of that conversion procedure.
02-28-2012 07:01 PM
03-01-2012 11:11 AM
Yes... Thank you Dennis... Did the way u suggested,aftr few trails of error got to know the basic settings to be done and got the initializing of the device successfully
..And by d way in the same manner v can modify rest driver vi like getting started.vi and application.vi rite???
03-01-2012 11:33 AM - edited 03-01-2012 11:33 AM
Typically, all you would need to do in any example would be to include the cluster for the serial port configuration.
