08-06-2013 10:39 AM
hi
08-06-2013 11:15 AM - edited 08-06-2013 11:16 AM
PCI 6221 is DAQ card with 68 terminals and SCB (Shielded Connector Board) 68 is termination board to those 68 pins of 6221 card, so that you can connect signals (to be measured) to appropriate pin of PCI 6221. You might already aware of it.
Refer to the pin out of PCI 6221 to check which is the correct terminal, for voltage measurements.
You cannot measure current directly, instead use a resistor of known value (and appropriate current rating), let current (to be measured) flow through it and measure the voltage across that resistor.
08-08-2013 03:33 AM
it is not sufficient for my knowledge
so plz help for the same.
08-08-2013
04:41 AM
- last edited on
11-21-2025
03:26 PM
by
Content Cleaner
Please upgrade your knowledge.
Edited: Refer to this link here.
