how to use scb 68(pci 6221) for voltage and current measurement
hi
(3,089 Views)
PCI 6221 is DAQ card with 68 terminals and SCB (Shielded Connector Board) 68 is termination board to those 68 pins of 6221 card, so that you can connect signals (to be measured) to appropriate pin of PCI 6221. You might already aware of it.
Refer to the pin out of PCI 6221 to check which is the correct terminal, for voltage measurements.
You cannot measure current directly, instead use a resistor of known value (and appropriate current rating), let current (to be measured) flow through it and measure the voltage across that resistor.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,081 Views)
it is not sufficient  for my knowledge
so plz help for the same.
(3,049 Views)
Please upgrade your knowledge.
Edited: Refer to this link here.
(3,039 Views)
