how to use threshold 1D array
I want to use threshold array, but my array it's ordered from bigger values to smaller values. It's important to mantain the order of the array and calculate the fractional index, because this value is important in another part of the programe. Any suggestions?
I attached the result for different inputs, the output is always the same, equal to zero.
Message 1 of 12
(7,992 Views)
Read the Help associated with the function.
Your array needs to be ordered low to high not high to low
 Use reverse 1D array
Ken
Message 2 of 12
(7,976 Views)
@IñigoP wrote: but my array it's ordered from bigger values to smaller values.
Use Reverse 1D Array  before using the Threshold 1D Array.  You can the subtract from then length-1 to get the index you want.
Message 3 of 12
(7,972 Views)
Message 4 of 12
(7,957 Views)
Or, just negate the array and the threshold.  Less math to deal with (Size- threshold) adds both an array size and a subtraction where the negate just flips sign bits
@IñigoP wrote:
Thank you fellas, but I found another solution here:
https://forums.ni.com/t5/LabVIEW/quot-Threshold-1D-Array-quot-for-descending-data/td-p/515581/page/2
And that example does not yield fractional indices- it yields integer indices after pos and neg going 0 transitions
Message 5 of 12
(7,944 Views)
Instead of reversing, which potentially needs to move every single array element in memory, negate the array and search term instead. Better in-placeness (unless the compiler can do some magic with the reversal). Now you even get the correct index directly.
Works just fine!:
(Note that the correct term for the array requirements are "non-descending", so you need to make sure this is true.)
Message 6 of 12
(7,930 Views)
@altenbach wrote:
Instead of reversing, which potentially needs to move every single array element in memory, ...(unless the compiler can do some magic with the reversal). ...
I think I read Stephen saying the start location of the array is set to the end and the stride is set to "-1" ?
Ben
Message 7 of 12
(7,927 Views)
"Threshold array" does not have an input for "stride". (and who is "Stephen"?)
Message 8 of 12
(7,923 Views)
The handle of the array keeps track of where it is in memory and the "stride" is used to adjust pointers into the array. By negating the "stride" the compile can reverse an array "in-place" and then the next node down the line can use the array but working backwards instead forward.
Stephen (AQ unless I spell his name wrong. Brain does not allow me to store correct spellings).
Ben
Message 9 of 12
(7,916 Views)
OK, I thought you were quoting somebody from this thread. 😉
Yes, for certain operations the compiler just flags that the array is reversed without making a new copy, but it is not clear if threshold array understands that flag (doubt it) or always expects a plain array. And we still have the problem that the returned fractional index is different from the index we want, i.e. the positions in the non-reversed array. I would go with "negate". 😄
Message 10 of 12
(7,908 Views)
