how to use treeview .net control
I've tried using .net ob to variant & variant to data, but getting following error:
Error 1 occurred at Invoke Node in .NET Object To Variant.vi->TestPanel.vi
Possible reason(s):
LabVIEW:  An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
NI-488:  Command requires GPIB Controller to be Controller-In-Charge.
Method Name: .NET:Convert Object To LabVIEW Variant
What may be the reason?
Shrini
Message 11 of 15
(1,780 Views)
Can you upload your code?
Message 12 of 15
(1,763 Views)
Attaching my code here. I can able to display Text & Item Check status.
Shrini
Message 13 of 15
(1,757 Views)
Well, I never claimed to be an expert on the TreeView control, but a read of the MSDN documentation indicates that the Tag property is something different. When using the Add(string, string) method, that sets the Text and Name property of the TreeNode. The Tag property is left at its default, which is null. Thus, you can replace the Tag property with the Name property. I've attached a cleaned-up version of your code. A few things to note:
  • You should wire the error cluster through for-loops using a shift registers - otherwise you will lose errors from previous iterations.
  • You should close references at the end of your program.
  • You don't need to have to read the cound each time in the while loop, since the treeview isn't changing content.
  • Even though you have a 20msec wait in the while loop, the .NET interface will chew up processor usage in your loop. I'm assuming that code is for proof of concept.
Message 14 of 15
(1,745 Views)
Thanks a million for code modification & suggessions.
Shrini
Message 15 of 15
(1,734 Views)
