how to use vkey with keyboard ENTER key instead of press button
Hi Ni Engineers,
In stead of using Send button, after i key command in a string control i wanna just press ENTER key in keyboard.
I delete the Send button, just use string binding VKey Event to trigger, can it work ?
can any body give me a clue?
thanks a million.
Amanda
(5,313 Views)
Accepted by amandarila
It can work. What are you having problems with? Have you just tried to create an event structure and handling the "Key Down" event?
(5,303 Views)
Yeah, i do want to creat a Key Down Event for string control to auto send the command to serial port.
so as to avoid pressing button.
I use your idea, and build a small vi, it seems work, but still exist some error, maybe i need use the property of updating when typing.
thanks.
Amanda
(5,287 Views)
thanks.
Amanda
(5,286 Views)
Please indicate what this "some error" is. Please post your VI and describe what is not working.
(5,261 Views)
