how to work in diferents sequences...
Sorry about the late reply.  It appears others have beat me to it.  Also, I too misunderstood what your real problem was.  It's with the timing, correct?  Can you post your code?
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 11 of 71
(1,011 Views)
@alan4 wrote:
PC2: from sec 0--> 10ms, read information from the PC1
        from  10ms--> 20ms, send information TO PC1
        from 20ms-->32ms, wait the start again doing this buckle
I THINK YOU WILL UNDERSTAND..IF YOU DON'T TELL ME AND I WILL TRY TO EXPLAIN IT BETTER...
THANK YOU!!
What does "wait the start again and doing this buckle" mean?  What is "buckle"?
Message 12 of 71
(1,006 Views)
"Wait, then go back to start and loop around"
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 71
(1,003 Views)
good morning...
here yoy have my code,
i use the same code for two pcs only i change the ip number...
the problem is that both computers are sending info in the same time so,they can not read in correct time...
so what can i do to correct this?
i think that giving times to every action will be the solution!!
what do you think!!
thanks for give me your help!!
Message 14 of 71
(987 Views)
First you can reduce the complexity of your code by getting rid of the sequence structure, it's not needed.  What are you using for timing?  Which PC is the host?
Message 15 of 71
(981 Views)
hi
i am using the same programm in both pcs...
i need timing because the pc gives information every 32ms...so i need to read it and send it to the othe pc...
and afther that i need to read information..so i think is quite hard...to explain also...i f you don not understand tell me and i explain it again more propperly!!
thanks!
Message 16 of 71
(978 Views)
What do you mean by this, they cannot read in correct time?
Message 17 of 71
(975 Views)
i am saying that  i use datasockets and if both pc are sending info same time, they can not read it properly the information is giving by the other opc..so i think thta i need to do sequencialii first one read the other send, second ...
Message 18 of 71
(973 Views)
i have just done this, but i have an error colud you help me please??
Message 19 of 71
(959 Views)
State the error.
Message 20 of 71
(949 Views)
