how to work in diferents sequences...
Error occurred at close file in "Program Name Here.VI"
Possible Reason(s):
LabVIEW: An input parameter is invalid.
NI-488: Command requires GPIB controller to be in charge.
Does anyone have any clue as to what this message is trying to tell me?
Message 21 of 71
(931 Views)
Its trying to say that an input parameter is invalid, ignore the text after that.
Post your code please, cant find Program Name Here.VI in the previous vi you posted.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 22 of 71
(925 Views)
here you have i am using labview 2009!!
Message 23 of 71
(921 Views)
I still cant find that vi. I am possibly missing a toolkit or something.
Message 24 of 71
(914 Views)
apart from that have you got an easy example of tcp ip?
Message 25 of 71
(910 Views)
I am guessing you have tried the examples that ship with LabVIEW?
The following links may be of help.
Client
Server
Also, a search yields a lot of results: http://search.ni.com/nisearch/app/main/p/bot/no/ap/global/lang/en/pg/1/ps/30/q/client%20server%20tcp...
Hope this helps.
Message 26 of 71
(906 Views)
u have changed the program and i have insert the tcp ipp protocol..can you watch it and say me why don not work good, i have two problems, can yu help me??
1-- no memor to work, says in the screen like an error
2-  i can se the array i have sent to the client
Message 27 of 71
(899 Views)
There are a couple of problems with your attempt, but you're moving in the right direction. 🙂
The producer (servidor) generates ALOT of messages, you'd do well to slow it down with a wait. (e.g. 1000ms)
The Client expects 2 parts of a message, [Message length], and [Message]. You never generate or send a message length, only the [Message].
The sender-loop has a 0 ms timeout, and you only send once it timeouts, which it wont do due to #1. (That's probably the memory issue)
I'd recommend a longer timeout, if any (-1 will only execute if there's a message, else it'll wait) and always send with message recieved.´
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 28 of 71
(885 Views)
Run the code in Highlight mode and you'll see where the problem starts in a better way.
/Y
Qestit Systems
Message 29 of 71
(881 Views)
i change something whats your opinion i have connection problem i expect you can resolve it...
thanks
Message 30 of 71
(880 Views)
